jozeppi Offline OP
Does anybody know if someone is reproducing the rubber strips over the rear wheel wells? They're located behind the upholstery (see pictures). If not, is there anything close?
Randy
[Linked Image from members.aol.com]
Randy Nudo
I would cut about an inch from the end and take that with me to all swap meets. We have a fellow on the West coast that is at all major West coast swap meets and has a huge selection of extruded rubber. Perhaps you will find a vendor in your area.
Agrin
jozeppi Offline OP
Thanks, Ray. We have a swap meet here next weekend as part of the 3rd Midwestern Nationals. Maybe I'll get lucky.
Randy
Randy Nudo
If you find someone who has a STEEL RUBBER Products catalog, you may recognize it in there. Each type has a picture for identification.
Agrin
jozeppi Offline OP
I have a STEELE RUBBER catalog, but couldn't find anything quite like it there. I may look a little further in other years and makes. I just sent them an email with the pictures to see if they can help.
Randy Nudo
Ray,
I searched and searched for this item and never did locate it. I did my best to restore the broken pieces I had with black silicone caulk and black RTV. The seal is just there to direct water away from the interior and as you know it doesn't show, so appearance was not a high priority.
Good luck!
Try http://www.restorationspecialties.com/ It is amazing some of the stuff they have auto
I am going to grow up someday!
jozeppi Offline OP
WOW! They have quite a variety of extruded rubber! I'll do some browsing through their catalog. There's got to be something close. Thanks.
Randy Nudo
They are good folks and they are quite knowledgeable. I have dealt with them for many years They also do many of the larger shows. They drive a BIG green bus!
jozeppi Offline OP
I sent the photos to restoration specialties, and they wrote back that they do not carry it. I guess it's back the swap meets!
Randy Nudo
jozeppi
If you find someone with that extrusion, please let me (and others in this chatroom) know. I need the same pieces for my 35 Coach. The ones I took out are hard as stone, and fractured, of course. While I prefer to use the correct part, I thought I would use a different section weatherstrip and cement it in well, if I can't find the correct extrusion. Mcmastercarr.com has a large selection of rubber extrusions.
Jim G
JimG
jozeppi Offline OP
Jim,
I will post a supplier if I find one. Both Steele Rubber and restorationspecialties.com said they don't carry it. Nothing in the online catalogs either (Filling Station, Obsolete Chevrolet Parts, Chevs of the 40s, etc.). Mine are also hard as a rock and brittle. I'm also planning on using some other type of extrusion if I can't find the original. As Hemmings has my upholstery backordered, I guess I have some time to do some searching.
Randy (jozeppi)
Randy Nudo
Hi Randy,
Was not aware that Hemmings was into the upholstery business. (Just pulling your leg Randy).
Agrin
jozeppi Offline OP
OOPS! A "senior moment" for sure. Hampton Coach for the upholstery, of course. Ray, I'll be contacting you for advice in the next few months or so as I start tinkering with the non-working radio that I bought on ebay. I've got a fair amount of experience with 50s-60s vacuum tube radios/tvs as my father was a tv repairman from about '47 to the early 80s. I started going on house calls with him when I was three (handed him tubes, tools, etc.). Even inherited his old tube checker that still works just fine. That's for another post, though.
Randy
Randy Nudo
