Posts: 320 |
hi All, another joyous day owning a Chev 4 ! was replacing a snapped axel in my 28 Chev 4 today and when i tried to fit the spare I had, found the spline was just a bit too big, Chevguru tells me it is a later 29 - 32 axel so i am offering it up as a swap to any one who can help me out, it is a fine axel very clean in the key way and spline just no good to me, RAY Sydney Australia. PS does this site have a swap posting I noticed the forsale ones
Posts: 320 |
Ok so is what I have a 29 axel or a post 32 axel? is the 29 axel the same as the 28 ? RAY
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Ray, A 1929 axle shaft measures 1.130" across the splines, A 1930-31 axle shaft measures 1.225" across the splines. 1930-1 shaft Diameter at the bearing is 1.378, and is the same for early production 1932, with late 1932 shaft bearing diameter 1.575"
JACK
Posts: 1,284 |
Hi Ray,
Chev Rear axle shafts 1925 to 1929 are the same part number.
When I reconditioned my rear axle I used replacement axle shafts from Billy Possum in the States, as they are made out of a higher grade steel. The Filling Station sells them also, but Billy Possum makes em.
Good luck.
Ray
Posts: 320 |
Been a sunny day here for the first time in a week so we went fro a drive in my partners 63 Chrysler, Just measured the Axle and it is 1.220" at the spline so a 30-31, thanks for the help guys. Will post a swap notice on the for sale thread I suppose tha is the right place ? RAYCYCLED
