EDNY Offline OP
Anyone out there make any steel repair panels for a 33 Master 5 window coupe? Could use the rear wheel trunk tubs and the lower cowl section with bead - passenger side(area noted in picture). [not my car in picture]
[Linked Image from i15.photobucket.com]
33Master5W
34Master3W
I believe I have the cowl patch panel-Would be cut from a donor-May have the LH wheel well -contact me at desoldcar@aol.com
Dale would you know where I can get a right lower cowl patch for a 35 high cab truck
I strictly deal in cars-Sorry
do you have the splash pan /under grill?
anybody have the splash pan for under thr grill
