#213532 07/17/11 12:11 PM
stan2 Offline OP
help I had our clutch cage rewelded, however to balance
the Clutch housing. the Shop wants to do it together with
the Flywheel. I have the Flywheel bolts out, before i go any further and screw things up. What is the best way to remove
the flywheel? Cheers Stan
the flywheel?
Grab the flywheel on each side with your hands...and then pull it off.
stan2 Offline OP
that easy? I see these wedges like axe hangle wedges are they of no problem?
The flywheel bolts hold the flywheel to the crankshaft. With the bolts removed the flywheel can be removed.
stan2 Offline OP
Thank's I have some hand yanking to try out.
Cheers
Stan
stan2 Offline OP
Got it off thanks, had to use an air chissle to get it started
and a piece of simple angle iron and a bolt a few taps and off it came thanks again
Cheers
Stan
http://wallcar.clickusfirst.com what we are working on
My grand dads only car purchase ever he bought it in 1938
Sure, glad to help. And remember....when working on old Chevrolets of that vintage, most things can be figured out with just a little common sense and by reading the repair manual. Vague as the manual is it still tends to be somewhat helpful.
Good luck with your project.
