#213138 07/13/11 02:43 PM
GreggD Offline OP
When reassembling my 28 differential, should I just put a light coat of oil on the gaskets or should I use some type of gasket compound?
Hi GreggD,
If you want to make sure it never leaks I always use gasket cement. Others may say just use a plain gasket, but 5 to 10 years down the track when a leak starts, well?
Cheers
Ray
I have had good results using Permatex Hi-Tac on the gasket first. It's a spray that will seal a paper or composite gasket and it stays sticky so you can stick the gasket to one of the mating surfaces and it will stay there while you get bolts in.
It's not how fast you can go, but how good you look at 20 MPH.
I always panel beat/straighten the edges of the diff cover as it usually warps between the bolts, this makes sure you get a good seal, and I always use 1/16" thick neoprene cork gasket as it allows for any indentations in the cover plate. Don't use too much tension on the bolts when tightening
Chris
GreggD Offline OP
thanks for the advise...will keep in mind.
