Does anyone reproduce the spherical shaped brake shaft bushings (four of them) that are sandwiched between the two riveted plates? I searched this forum, The Filling Station and Gary Wallace without any luck...
Thanks,
Jeff
Member # 8618
Down here in Aus. someone has made Nylon versions of them, if you can't find any I can make some inquiries to see if they're still available.
Chris
Thanks Chris!
As a last resort I can have them made. I have a friend at a machine shop and for a few beers he will help me out.
Jeff
Thanks,
Jeff
Member # 8618
Hi Guys,
As I recall, well over 20 years ago I made mine out of a straight bronze bush. I got the angle right, and bored each plate so I press in the straight bush. Have had no problem since.
Cheers
Ray
I seem to recall a thread on this topic some time ago - possibly Arvid, I shall have a look - I replaced the bushes on my 28 one ton with Nylon but didn't like the karma so had some bronze 1 inch ID bushes machined down. I'm surprised someone like Billy Possum hasn't gone into production.
Hello BOPNZ
You are right.
Here are some of the thread almost 5 years ago
https://vccachat.org/ubbthreads.php/topics/58390/Re_Cross_shaft_wear#Post58390
Arvid
Thanks for your reply! AFter reviewing the center support plate (2 pcs) I need to make six bushing total.
Thanks,
Jeff
Member # 8618
