Posts: 109 |
what year did chevy go the the spin-on oil filters? thanks.
Contrary to the rumors, I'm making great progress on the bulb. So far I have found 169 things that won't work.---Thomas Edison.
Posts: 1,194 |
I had a 1968 C20 with a 327 that still had a cartridge filter. I think that the change was in 1969 or 1970.
Passenger cars 1968 for sure Trucks 1969 if I remember correctly
Posts: 4,951 |
Boy, I'm on shakey ground here (sorta disagreeing with Gene) BUT my 68 Impala convertible, purchased in 1991 from the second owner, had a cartridge, not spin-on. It had a basic 327, 275hp engine with a TH-400 trans. I was told it had the original engine and trans. Also was told it was an "early" car. Would being an early '68 make any difference???????
Bill.
Posts: 109 |
Posts: 11,162 |
Rockauto sells both types (cartrige & spin-on) for the 68 327-275HP engine. My 68 Sport Sedan with 327 275 Hp and TH400 had a spin on when I changed it after I bought it. The original, to me, was one from a quikky oil change place , not a name brand.
Posts: 1,194 |
In the early 70's I worked in a gas station and it was common to install an adapter so a spin on oil filter could be used. Don
