birtch Offline OP
The wiring on my 1950 Chevy coupe with powerglide is at the point I am worried.
Does anyone make an original looking wiring harness?
What is involved in converting the 6 volt to a 12 volt?
thanks
The Filling Station in Lebanon, Oregon has the wiring harness. The complete harness sells for around $583.00.
Rhode Island Wiring Service not only sells the harness, but all the extra wires like accessory wiring, heat wire, etc.
Most of the suppliers re-sell the RI Wire bundles anyway.
Customer support is good too.
You can use the harness for 12 v as it requires less current and the heavier 6v harness works fine. Make sure you buy the current limiters for all your gauges and fuel sending unit and get a 12v coil also. Chevs of the Forties, Filling Station, and Natl. Chevy all sell these.
Rick
