Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Hi all, Does anyone know if these windshield pivot from Snyders will fit and work on 1931 roadster, phaeton and tourer windshield frames. From what i have seen , there is two parts used on chevy pivots, this type, an inner attached to the frame with a stud, and then an outer sleeve over the top. http://www.snydersantiqueauto.com/3367http://www.snydersantiqueauto.com/2331http://www.snydersantiqueauto.com/1505Thanks Jack
JACK
The Snyder parts are not exact as the Chevy windshield (windscreen in OZ) frames are oval and not as round as the Ford. I had planned to order a set to see if they are the same diameter and taper but have not done that yet. I have this thought in my head that they are smaller diameter but don't know for sure.
Chipper, Thanks for the insight, i looked at the pictures at Snyders again, and you can see the large round ends which you describe.
JACK
