I need help, I have a 64 4 door impala and want to convert to disc on the front. I need to know if their are rotors and calipers I can use from later
chevy's?
Wilwood Engineering1955-1957
Give this a read, it lists some parts that work, although they are particular to the brackets being sold. But if you are going to run stock 14" wheels, then you may be interested in their brackets.
http://www.scarebird.com/index.php?id=12
Also a lot of info here, but it is a long topic and some is related to lowrider specific things. However the info you want is buried in there.
http://www.layitlow.com/forums/showthread.php/225581-1964-impala-from-drum-to-disc?highlight=disc
David Cairns
1964 Impala 4 door sedan
My 1964 Impala Restoration Blogish Thing
