How much vacuum do you use in trying to get the motors to work? It takes ~12" or more for most motors to work. What lubricant are you using? Do you use new seals on the paddle or just reinstall the original?
I have both new seals but on this one I made some from a cardboard box. Slightly thicker than the seals I bought.
I have over the 12 vacuum. I am proud to announce that I have one of mine working now and installed. I had to keep cleaning the inside to smooth out all the bumps. I used a new paddle and it is pretty hard to get that in correctly. Especially the short end. I get the cover on with one side of the paddle bent the right way which of course bends the other side the wrong way. Then I use a "L" shape smaal tool and help bend that side of the paddle into position. You can't really see it just kinda by fell and is hard to do with only 2 hands.
I thgink the biggest help I got was a reccomendation to use whell bearing grease. I had some "blue" which I used and I guess it was the trick. Now onto the next one.
I am curious about the 'PARK" position ? Is it supposed to be towards the passenger side as mine does?
