#210644 06/19/11 09:59 PM
goffe Offline OP
I need to redo the radiator shell lacing on my '32. I came across a thread from 2005 discussing for the '31 modifying the double bead lacing to single bead and split riveting to the shell. Does this hold true for the '32 as well?
Yes.
I got radiator shell lacing from the filling station and it doesn't have a bead on it at all is it incorrect?
Thanks todd
The original lacing for the radiator shell should have one bead.
which side should the bead be on, the if your looking at the shell from the drivers side, left or the right of the rivet?
The single bead is on the engine side of the radiator shell.
