#21035 06/15/04 12:41 AM
jozeppi Offline OP
After dropping the transmission, to change the clutch in my '36 Master, I decided to do an overhaul on the WM transmission. Definitely found some gears that were well worn, especially the 1st and reverse gear, and reverse idler gear. Are there other parts that I should change while I'm doing the overhaul, even though they look ok? For example, front and rear bearings, synchronizing drum, shafts??
Also, I see in the shop manual that there were two 3-speed transmissions available: the WM series, and a synchro-mesh. Does anyone know what difference there is in performance of these two transmissions? Are any of the parts interchangeable? The only parts I have found (Obsolete Chevy Parts) have part numbers for the synchro-mesh. Thanks, guys rnudo@kumc.edu .
Randy
Randy Nudo
#21036 06/15/04 06:51 PM
They are to different transmissions. I have some new parts for either maybe I can help. I dont think much of anything interchanges.
#21037 06/15/04 08:21 PM
jozeppi Offline OP
Thanks for the info, chevy b. The parts that are the worst are the reverse idler gear (part # 476299) and the 1st/reverse gear (part # 476191). The syncronizing drum should probably be replaced also, possibly only the ring. Part numbers are 592776 and 476300, but one of these numbers might be for the complete drum assembly, which I'd prefer if available.
My other option that I'm considering is to find a complete synchro-mesh transmission if it performs significantly better than the WM. Any ideas on this?
Randy
rnudo@kumc.edu
Randy Nudo
#21038 06/19/04 06:04 PM
If you find a used transmission it must be from a 1936 Master-will need it to be complete including lever.The WM trans. used the same gears as a F*%d-except the front and rear shafts-main drive gear and main shaft.It was a Warner unit.
#21039 06/19/04 11:14 PM
jozeppi Offline OP
That's great! The parts that I wasn't able to locate (e.g., reverse idler gear) are available through the F*%d parts dealers. Reverse idler gear looks identical at Mac's Antique Auto Parts (same number of teeth, straight teeth, etc.). I may have her back on the road for the 4th of July after all. laugh
Randy Nudo
#21040 06/20/04 08:23 PM
You might also check out Vintage Auto Parts, Inc on line catalog - http://www.vapinc.com - They show a fairly complete listing of 1936 Standard and Master Transmission Parts
Herb
#21041 06/21/04 10:57 PM
jozeppi Offline OP
Yes, I even called Vintage Auto Parts, but they only seem to have the gears for the synchromesh transmission in the catalog. They were supposed to do a search of their inventory, but that was last week and they haven't called back. Early F%#d V8 had all the parts I needed. The non-synchromesh Chevrolet transmission used many of the same gears as the F%#d 3-speed transmission, as Chevgene said. Early F%#d V8 had the reverse idler gear, idler gear shaft, countershaft, synchronizer hub with new brass rings, springs and ball bearings. Shipped the same day too.
Randy Nudo
#21042 06/23/04 12:49 AM
Here is a little more info on the two transmissions.
From 4-23-35 thru 5-11-35 the Toledo Transmission Plant was on strike. Chevrolet contracted with Warner as a "stop gap" and started using the "WM" transmissions in late '35 Masters and early '36's.
The shift lever is located further forward on the WM, so if you swap it out with a Toledo unit you will need to get the correct floor inspection cover and floor mat. The WM also uses a different bell housing. The shifting rods slid out of the front of the WM transmission and extend into the bell housing holes.
The ratios are also different, the WM has a lower ratio (better on hills):
Toledo is R = 3.40:1, 1st = 2.02:1, 2nd = 1.70:1 and 3rd is direct.
WM is R = 3.38:1, 1st = 2.82:1, 2nd = 1.60:1 and 3rd is direct.
Mike Boteler
1935 Master Technical Advisor
#21043 06/23/04 08:35 AM
Slight error-1st gear in Chevrolet built Toledo is 3.02
#21044 06/23/04 09:58 AM
Mike,
Maybe that's why the taupe floor mat from Hampton doesn't fit my WM shifter! By the way, does anyone make the mat anymore? Last I checked with Hampton they couldn't get these anymore.
#21045 06/23/04 10:27 PM
jozeppi Offline OP
Regarding the '35 Toledo strike, it is chronicled in a book called Not Automatic: Women and the Left in the Forging of the Auto Workers' Union by Sol Dollinger and Genora Johnson Dollinger. I haven't read it, but I'm curious enough now to pick up a copy.
Randy Nudo
#21046 06/23/04 10:43 PM
Mike, My 1929-39 parts book lists the same bell housing for all 1935-36 Masters.Could the WM housing be used for the Chevrolet Toledo trans. allowing parts to stock only one unit?
The "higher ratios " would be great in my '34.Would get 25 MPH out of 1st gear rather than 23 MPH and 46 MPH out of 2nd.Wow.....I could see where it would improve 2nd gear for hill climbing as slightly higher speeds could be maintained.Was surprised a couple of years ago.I noticed the higher shift tower in a members '35.Was curious to hear if the WM sounded like a Chevrolet unit in 1st and 2nd gears.Really couldn't hear much difference.
#21047 06/24/04 10:50 PM
jozeppi Offline OP
I received my F%$d transmission parts from Early F%$d V8 today. I can verify that the reverse idler gear, idler shaft, synchronizer hub, and front bearing are identical to the WM parts. Unfortunately the counter shaft is different. Although it's the same length, it's 3/4" diameter and mine is 7/8" diameter. My parts book says that the 3/4" shaft was used on the '35 WM transmission, and the 7/8" shaft was used on the '36 WM. Not an expensive mistake, but it looks like only some parts are interchangeable.
Randy Nudo
#21048 06/24/04 11:01 PM
IF WM changed it for Chevrolet it must have been changes for all the transmission applications.Would check if they have a larger one for brand F.
#21049 06/25/04 09:53 AM
jozeppi Offline OP
According to Early F$%d V8, brand F used the 3/4" shaft at least through 1948. They didn't have a 7/8" shaft.
Randy Nudo
#21050 06/25/04 11:08 AM
:) Must have saved the best for Chevrolet :)
Note that the heavy duty 3 speed Warner optional truck trans from 1954 and up used a 7/8" shaft-2 1/2" long.Also the Corvette Warner 4 speeds used a 7/8" shaft but 5 1/8" long.
#21051 06/25/04 12:21 PM
jozeppi Offline OP
No doubt! FYI, this is the shaft for the cluster gear and it's 8 9/64" long.
Randy Nudo
#21052 06/25/04 03:08 PM
The truck heavy duty 3 speed and a Corvette type 4 speed use the same cluster shaft.Its 7/8" dia. and 9 7/16" long....probably available thru Vette suppliers etc..and could be cut down???
#21053 06/26/04 01:20 AM
Hey Gene...thanks for catching my typo. You are correct it should have read 3.02.
The Hampton Coach floor mats were made by Dale Miller (I believe) and he is no longer doing them. The WM mats were never done to my knowledge.
The WM bell housing is not the same as the Toledo one. I can't explain why the parts books left them out (not in my 29-36 book either). Maybe Chevrolet figured if you needed a bell housing you had biger problems and they would convert you back to a Toledo trans set-up. I need to take some measurements to see if the Toledo trans will fit a WM bell housing (that might work). I know a WM trans won't work on a Toledo bell housing. The shift shafts will strike the back of the bell housing as they exit the top cover making it so you can't shift.
Mike Boteler
#21054 06/27/04 12:19 AM
jozeppi Offline OP
I got too impatient to get the tranny back together, so I decided the main shaft wasn't so bad. Of course, I bought a gasket set that also happens to be for the Toledo transmission. The only one that's interchangeable is the gasket for the front bearing retainer. It doesn't look like anyone sells the WM gasket set. Anybody have any leads? The universal gasket material sold by the local parts stores is cork, and I think it will be a little too thick. Does anyone sell the "paper" gaskets as universal material?
Randy Nudo
#21055 06/27/04 08:58 AM
My local parts stores sells rolls of paper gasket material.Even available in more than one thickness.The last I bought was from Checkers Auto Parts.
#21056 06/27/04 11:08 AM
jozeppi Offline OP
Thanks. I'll try a few other local parts stores. Advance Auto Parts has it online, but not in the local store. Regarding the Toledo vs. WM housings, my 1929-1942 master parts book lists several transmission cases for 1935-1936 3-speed. Unless stated otherwise, I think these include the plugs. Also, unless stated otherwise, I think they refer to the Toledo synchromesh transmission:
590531 1932-36 B, CA, CB, DB, EB, FB
590697 1934-36 DA, EA, ED, FA, FD
476017 1935 (less plugs; 3/4" countershaft holes; WM) EA, ED
592698 1936 (less plugs; 7/8" countershaft holes; WM) FA, FD
601993 1935-36 EC, FC
So in '35 and '36, one of two 3-speed transmissions were used on standards and masters. Since the F%$d parts that I bought included the 3/4" shaft, it looks like they used the same WM transmission that Chevy used in '35.
Randy
Randy Nudo
#21057 06/27/04 10:45 PM
The 1933-36 Standard transmission was a light weight non-syncronized unit.No parts interchanged.The 1937-1965 3 speed (many improvments made during that time) was an entirely new transmission, much lighter in weight than the 1932-36 Master, and had a better syncronizer that would allow much faster shifts.There were two versions of the original unit in 1932.The first design used a straight cut gear for 2nd speed making it very noisey.The late version was described as being silent in 2nd-but that was not completely true-but it was a great improvement.
#21058 06/28/04 11:31 AM
jozeppi Offline OP
OK. I won't expect my rebuilt transmission to work like one from the 60's, even with a new synchronizer hub. I'll post an update when I get it back in the car this weekend and see how she runs.
Randy
Randy Nudo
#21059 06/29/04 11:39 AM
jozeppi Offline OP
Just one more note to document incompatibilities for anyone doing this in the future: The universal joint is also different. I found a NOS U-joint for a '36 Master on ebay, but it's different. My U-joint that fits on the WM transmission has a gear that drives the worm gear for the speedometer cable. The front plate of the U-joint also has a slightly larger opening to accomodate the gear. I was able to use the NOS bushings, rear plate with my old U-joint gear and front plate.
Randy Nudo
