#210250 06/15/11 04:13 PM
Bobn Offline OP
I am looking for a engine manual for 1922 FB-50 touring, got to pull the cam and reinstall stuff on engine, need Info about front pulley removal?
also will be looking for cam or rebuilder
thanks
Bobn #210266 06/15/11 07:06 PM
Hello Bobn,
welcome to Chevy chatter, There is a workshop manual and handbook for sale on ebay at the moment which covers 490 and F FA FB series.
It is a bit pricey, but will show which manual covers your vehicle.
http://cgi.ebay.com/ebaymotors/1919...nuals_Literature&hash=item1c0a81f5c9
http://cgi.ebay.com/ebaymotors/1919...nuals_Literature&hash=item1c0a81f528
JACK
jack39rdstr #210291 06/16/11 12:15 AM
The 1919 repair manual has been reprinted. I have a repair manual dated January, '22 that does not show the three port head. Never seen one that does.
I have a '19 RM (reprint) that I would sell for much less than the ebay one.
Chipper #210313 06/16/11 11:32 AM
I have a 23 Oldsmobile truck which uses the same engine as an FB. The front pulley on my truck is just held on by a bolt that goes through the pulley and also through the crank to hold it on. It slips off the front. Now not 100% sure if that is totally stock like that.
28 Chevy LO Capitol 1 ton, 28 National 2 dr coach, 71 Chevy Custom Camper 3/4 ton. Also 23 Oldsmobile Economy truck and a 24 Olds sport touring.
Chipper #210367 06/17/11 12:48 AM
Bobn Offline OP
I m interested in your manual , trying to figure out how to remove the crank pulley
Bob
Bob_Kerr #210368 06/17/11 12:49 AM
Bobn Offline OP
thanks Bob, I can't see a bolt head in the pulley , maybe its back in a ways?
Bobn #210370 06/17/11 02:04 AM
To remove the crank pulley ,the repair manual shows to use a puller wth a centre bolt winding against the centre of the crankshaft. The puller is shown on page 168 of the manual.
Basically it is a flat steel bar , bent 90 degrees on both ends, to give a dimension of 4 1/4" inside.Then bent again at 90 degrees to make a U shape on each end. the last bent piece is tapered to suit the shape of the fan pulley. 1 1/4" inside dimension.
The centre of the puller is threaded for a bolt , which is shown as 9 1/4" long , with the the threaded end ground to a point. If the radiator is removed you could probably use a shorter bolt, the 9 1/4" bolt will allow the pulley to be removed with the radiator installed( shown in removal procedure picture).
JACK
Bobn #210371 06/17/11 02:14 AM
The pulley is normally a pressed on fit without any need for a retaining bolt.There is no mention of removing a bolt in the pulley removal procedure in the repair manual.
JACK
jack39rdstr #210473 06/18/11 01:40 AM
Bobn Offline OP
thanks Jack,, I think thats it I will have to fabricate a small puller , getting ready to pull the body off the frame, dont want to tweek it so will put some 2x6's along bottom to hold everything in place while I lift it, then I can get to everything
Bobn #210526 06/18/11 03:36 PM
The bolt in mine is just behind the ears for the crank handle and goes all the way through with a nut on the other side.
