I have a 57 sports coupe with a 283, automatic transmission, and all stock equipment for the most part.
I have had some problems lately with the engine getting too hot.
The temp gauge goes to the right 1/2 of the gauge and if I don't keep her moving the gauge will go almost to the far right.
I can smell it getting hot, and when I stop the radiator cap would boil over if I took it off.
I suspect that the thermostat is not opening?
If I replace the thermostat is there a replacement temp that I should use? Thanks Paul
Nice car. I had one back in the '60s and it was a mover until my sister pulled it out in front of a truck and bent it all to pieces....
With the radiator cap off, make sure the coolant level is where it belongs, start the engine, and check to see if there are any bubbles or oily residue. Also check the oil to see if there is coolant in it; it would show as a whitish froth.
Anyway, the thermostat sounds like a good place to start, but the keeping it moving to keep the heat down suggests that maybe the radiator needs cleaned out. Check the outside first. Sometimes just running water through the vanes to get rid of dirt and debris will take care of the problem. Do it with the engine running, and the fan will help pull the water through. You can also look from the side and see if there are any dead spots where water is not coming through. Also check for bent vanes and straighten them if you find any.
If that isn't the reason for overheating, go ahead and change the thermostat. Since you live up north, I'd go with a high temperature one (194) to get the temp up fast in the cold. See if that took care of your overheating problem.
If not, run it with the radiator cap off and see if there is flow of coolant when it heats up. Just look inside the radiator and you should be able to see it flowing. If you're not sure, rev the engine up a bit and drop it back to idle. If you're not seeing a difference, you most likely need a radiator flush. You can do that yourself, but with the problems of getting rid of the old coolant and chemicals, you may be better off having a radiator shop take care of it.
IF YOU DO IT YOURSELF, BE SURE THAT NO CHILDREN OR ANIMALS CAN GET TO THE ANTIFREEZE. IT TASTES GOOD BUT IS DEADLY AND CAUSES A VERY PAINFUL DEATH! EVEN A SMALL AMOUNT CAN CAUSE SEVERE DAMAGE TO THE LIVER AND CAUSE IT TO SHUT DOWN.
