I have two of each of these. First set "Delco Remy Electrolock C1615" second set Briggs & Stratton Corp. C1695". The Delco key is an oval shaped grip with a bump on top where the hole for a chain or ring is. The Briggs key is a round grip with a hole. All have the name "BASCO" on the back side. They all seem to go into my electrolock but none turn it. Are they all ignition keys?
Thanks for any help you can give me.
Dan
I believe the clover leaf one is for ignition & the round is for the door...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
Thanks. I forgot about the possibility of a door lock. Alas, I only have one handle right now.
Dan
