#209471 06/08/11 03:31 PM
virg912 Offline OP
Is the same stater used on a 54 powerglide and a 3 spd manual? Virg
virg912 #209475 06/08/11 04:14 PM
No, the manual transmission engine uses the two field starter while the Power Glide engine uses the 4 field starter.
Agrin devil
AntiqueMechanic #209522 06/09/11 07:29 AM
virg912 Offline OP
So the 54 PG one should still work with the 3spd? I was concerned about the matchup with the flywheel.....Virg
virg912 #209526 06/09/11 07:56 AM
GM parts book shows 49 to 54 starter as being the same, whether stick or automatic. Starter drive is the same, as well.
