Thanks guys! The engine actually came from a truck (and I understand that it had been re-engined) and it came with a QJ. Does anyone know where the vacuum advance connection comes off the carb?
I have a 1970-87 Chilton Chevy Pickups and Suburbans manual. While it doesn't give specific diagrams, it goes through the basics of all the emmissions controls, what they look like, and where they hook up. It can be an educational experience to go through such stuff. Oops; turned the page and they do have some diagrams that should show you what you need.
If I remember correctly, most of the vacuum connections are on the front and rear of the carburetor base with secondary connections like temperature sensor, EGR and such spread around the engine. Remove anything you don't need and plug it. If you need one connection where there are three or four, remove the gang connector and replace it with one that has only the number you need; it just looks neater.
The vacuum advance may have two connections to it; one straight from manifold vacuum and the other through a bypass valve. You can most likely get by with just the straight one that comes off the front of the carb, second one from the passenger side; depending on the carb used.
There is usually another vacuum inlet directly into the manifold for the automatic transmission and PCV valve; keep the PCV.
It looks like 1977 was the first use of the 305, and that would probably be the best starting point for tune up specs with most of the emmissions controls removed.
