Posts: 37 |
I've pulled the rear suspension out of the truck to re-gear the diff and repair the ravages of time. Since this truck will be a daily driver and also unlikely to carry more than a hundred pounds in the bed, I'd like to improve the over-the-road ride quality. Has anyone played with the number of leafs and specific shocks to get a more passenger car ride? I know the weight distribution differs between truck and car, so an exact duplication probably won't work well, but some combination should improve the ride. Also, has anyone used the poly strips between the leafs to eliminate the frictional damping? And, if so, did it require a change in the shocks to make up for the lost damping from the springs and did they last?
Posts: 1 |
You can put 1mm thick metal strip between the leaves in order to reduce friction.
Also, has anyone used the poly strips between the leafs to eliminate the frictional damping? Yes! Don't do it!!
Posts: 37 |
Gotta ask! Why not, and are you talking about the metal strips or poly strips or both???
Posts: 37 |
Thanks for the input. I figured they'd work their way out from between the leafs, since they were slick enough to remove spring friction. I may try to drill the leaf ends for buttons.
