Does somebody have the correct bearing numbers (Timken, etc.) for the front wheel bearings that fit on a 1934 Master?
I can purchase bearings through work at a discount but need the numbers to cross referance.
Thanks,
Jeff
1934 4 Door Master
1927 Runabout truck
1937 1/2 ton truck
1957 Nomad
If yours is a DA then I think these are the SKF numbers
G909001
G909002
Neil (Canada)
have a nice day
I called our bearing supplier which does a excellent job for me and has never had a problem cross matching bearings.
They say the numbers are no longer valid for SKF and can't match it to anything. Does anybody have a modern equivalent number?
Thanks,
Jeff
1934 4 Door Master
1927 Runabout truck
1937 1/2 ton truck
1957 Nomad
I just called my supplier who lists the same numbers, but without the G prefix but they are BCA Bower brgs but he wouldn't know if they are available unless he called his supplier.
Neil G.
have a nice day
SKF numbers are B02 and B01. BO1 is stocked.B02 isn't in stock.
Hope this helps your Bearing guy.
Neil
have a nice day
New Departure 909001 and 909002
My bearing supplier checked with his 5 top bearing suppliers and confirmed that these bearings are not stocked anymore and the bearing manufactures have no plans to reproduce them.
Has anybody switched over to tapered roller bearings? Will they be more readily available for the future? Part numbers for these bearings?
Thanks - Jeff
1934 4 Door Master
1927 Runabout truck
1937 1/2 ton truck
1957 Nomad
The Filling Station has the bearings that you require listed in their catalog.
I have NOS New Departure for nearly all models 29 up
Wes
