Posts: 97 |
Is the throttle linkage the same on a 50 & 54 (car)? Virg
Posts: 97 |
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
You need to look through the 1929 to 1954 parts & accessories catalog to compare part numbers.
Posts: 1,178 |
I would say yes, there was next to no change in the blocks, manifolds, and linkage set up. As suggested a check of the parts book would confimr this.
Posts: 366 Likes: 1
Posts: 366 Likes: 1 |
I swapped a '54 PG 235 engine into my '50 StyleLine and the linkage did not need to be changed.
Dean 50 - VCCA #44675
Posts: 97 |
that is what I am doing, maybe I just bent something...thanks, Virg
Posts: 89 |
When I put the 54-235 in my 51 I had to move the linkage from the middle of the block towards the back of the block.
Posts: 1,113 Likes: 1
Posts: 1,113 Likes: 1 |
When I swapped a '54 235 into my 51, I had some minor issues with the pivot to carb linkage. Had to tweak that a little as I kept the manual choke 51 Rochester carb. Also had to adjust the accel pedal to block rod length by turning fitting. It's a little short but it works.
Rick
Posts: 97 |
Ok, thanks, still working on it....Virg
