Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Whilst cleaning out my old parts, I came across a couple of "Perfect Adjuster for Chevrolet Point Steering." The part consists of a "U" bolt (about 3 inches or so), saddle, center bolt in the saddle with adjusting threads etc. I was wondering if anyone was familiar with this gadget, how it was used, and what it was supposed to help/assist. The saddle also has a groove and there is a rubber ring to fit in it. The unit is made by Perfect Equipment Co. of Kokomo, IN. Thanks, Charlie
Posts: 11,162 |
I have one of those it goes on the center point as listed, Mine is an aftermarket and I haven't needed it yet for my 51 and 53, It takes the flop out of the center point when it get's worn.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Posts: 1,294 |
Posts: 11,162 |
The parts attached to the center of the front crossmember is what I call center point steering parts, including the tie rod ends in the center. ![[Linked Image from chevy.oldcarmanualproject.com]](http://chevy.oldcarmanualproject.com/shop/1949_53/03front/3-02.jpg)
Is this "unit" a "shim", of sorts to remove excess play from idler arm ?
Posts: 11,162 |
I'd say it is more like a clamp. This is one on eBay, Mine isn't like this but does the same thing.
Posts: 11,162 |
If anyone is interested in a complete used setup for a 49-52 Chevrolet steering linkage, there is one on ebay, expires in 7 hours, starting bid is $49. Here is the item # 260790750366
Posts: 88 Likes: 1
Posts: 88 Likes: 1 |
If I could only read those instructions in that photo you posted from E bay. It might make a it little more clear where how this device works. I understand the center point location but don't make connection on how it works in taking up the slack. What does the u-bolt go around? later, bill
Posts: 11,162 |
It is clear to me that it goes around the part that swivels where the bracket is attached next to the crossmember. Reach up under the frontend and grab the tie rods where they attach in the center and see if you can move the m up and down and side to side showing if there is slack in the joints, the aftermarket device is kind of like putting on a band aid, but they do work.
MrMack, That is a picture of exactly what I have. Thanks for posting the photo. Charlie
Posts: 88 Likes: 1
Thanks so much for making this clear... later, Bill
