#207472 05/22/11 02:06 PM
virg912 Offline OP
Is here a floor shifter available for a 50 3 spd car? I seem to be haveing trouble with the colum shifter...Virg
N.C.A. has a floor shift available, but it would be nice for you to figure out what's wrong with the column shifter, not all that complicated.
Do you own a 49 to 53 service manual with the 54 sdupplement? Well worth the $20 or $25 to buy it. You could spend the same amount on aspirins without the manual !
Virg -
What's the shifter doing or not doing?? Fairly simply to work on. Am sure someone here will be able to help you. Just my humble opinion, but normally easier to fix than switch.
Best to ya.
Jim.
virg912 Offline OP
I got the shifter from a friend yesterday from a 52, hope it is the same....I don't know what is wrong yet with the other one...Virg
Sometimes things just get gummed up. If you use some penetrating oil on the rod that goes into the top of the shifter box that may help. Also check the shifter support collar in front of the steering wheel and make sure that its not stripped out. Don
A lot of people dont know the top support collar has threads in it. I learned the hard way.
Virg,
If you are talking about the shift housing (box) on steering jacket under hood, they list the same from 49-53. Most everything is the same with stick shift from what I can see. If you think that the problem is in that box, try taking off the cover and looking inside and you will see how it all works.
Best to ya.
Jim.
virg912 Offline OP
I pulled the seering wheel and took out the old shifter, the threads on the clamp up by the wheel were all stripped, the 52 rod was longer so couldn't use it, just used the clamp on the colum but for some reason the 2 screw holes are in a diff. locatin. I haven't redrilled the holes in the colum yet but I guess I will have to. Will get back on it today to see if that is what I have to do...thanks....Virg
The part number for the upper support is 3686806. It should be the same for '49 to '52. The part number should be stamped on the part. If you look at it as you were sitting in the drivers seat the part number will be on the bottom of the circle. Its hard to see but its there. Don
virg912 Offline OP
I finally gotit to work bt it is hard to get n reverse. I was wrong about the screw holes too.
Virg
You may have to adjust the upper support. Its explained in the shop manual.
