41guy Offline OP
Rebuiulding master cylinder on 48 Chevy 2dr Fleetmaster Coupe.
MC piston from Chevs of 40s looks alot different than the old one. (Old one fairly matches the one in 42-48 shop manual). The new piston has an extra 3/16" thick "rib" as part of the casting, approx. 1/2" from outer end. On the other end of new piston, the 6 small holes are covered by a very thin spring-steel disk secured to the piston at its center. The disk has 6 holes, each approx 1/8" dia, arranged in a circle. These holes do not reveal the 6 holes in the end of piston.
Should I use the new piston, or re-use the old?
The rubber on old piston is not bad; have not tried removing the rubber from new piston to put on old piston, but will do so if you think I should re-use the old piston.
41guy Offline OP
Have been advised that the Chevs of 40s replacement reflects improvements made over the years & is OK to use.
