#207364 05/21/11 07:38 AM
virg912 Offline OP
Is there a little spring or just a washer and cotter pin where the shift rod hooks to the transmission .....wish I had taken pics
thanks Virg
virg912 #207368 05/21/11 08:53 AM
There is a small spring as well. set up would be spring first, then larger washer then the cotter pin. Spring acts as an anti rattle and also takes up some free play as the holes wear larger. talk
glyn #207384 05/21/11 11:07 AM
virg912 Offline OP
I thought they took a spring but wasn't sure....thanks
