pushrod Offline OP
did the 327 engine intake manifold have a isolator below the carter 4 barrel carb the studs in the manifold appear to be long enough if they are original to the engine thanks
Wilwood Engineering1955-1957
There was just the usual thin metal/asbestos gasket under the carburetor.
Bill, did you get my email concerning the W W arms?
Don
