I am in the final stages of finishing up the restoration of the truck and need a favor. I need someone to measure the distance from the top of the steering column to the bracket that mounts the column to the dash. We have repainted the column, but noticed a small scratch in the paint that appeared from who knows where. Before sanding and re-shooting the column, would like to know if it will show once its put into the truck, and if it is below the dash mount bracket, no big deal. But if it is above the bracket, back into the spray booth! Anyway, with the cab and everything still disassembled and off the chassis, I can't guess as to this measurement, so if someone could check their own truck and let me know, that would be extremely helpful.
Thanks much!!
