#20614 01/08/04 11:35 PM
vandrof Offline OP
I'm needing a Head for a 206 Cu In engine. The one I have I'm told can't be repaired.
I suspect the people that told you that the casting was not repairable were at the automotive machine shop. I also suspect that there is a casting repair business in Oakie City area. If you take the head to someone with expertise in casting repair likely it can be fixed. It will likely be expensive (hundreds of $$$$). I also believe that Mr Reynolds is somewhere in OK. Since I gave up on Hemmings I don't have an address.
