can anyone tell to me,what is the travel distance of the plunger in accel. pump on my 31--rjh-08 carb?? It appears to only move a very small distance---maybe 1/4--3/8 inch,depending on which hole i use?? thanks for any info,jay
3/8" +/- is about right.
Thanks Chipper---exactly the answer I was hoping for. Finally something on this ol car that is actually as it should be-lol!!
Thank you again,jay32249
remember those holes are there for a reason depending on season-if it doesn't stumble you probably have correct setting if everything else is in order
