#205313 04/28/11 12:00 PM
Am adding belts to the rear seat on my 48 coupe.
There are some rubber plugs in the floor just behind the rear bottom cushion. Can these be used? Looks like one of them won't line up because of brace in the way. Only going to put in two. Anyone one have pictures of your installation?
Keith Knox #205335 04/28/11 07:49 PM
Hi Keith, This is how I did belts in my 41. Don't know if I could have done a better job on the back seat belts? This area is a little more heavy duty than just the floor. You need to use the best bolts available, and assume that the seat belt anchors would just tear through the floor without a lot of reinforcement. I think I have done an advanced search on this topic, and not much has been discussed? Hopefully, others will give their two cents. This is a very important consideration when you expect others to ride in your car, especially children?
[Linked Image from inlinethumb56.webshots.com]
[Linked Image from inlinethumb64.webshots.com]
[Linked Image from inlinethumb37.webshots.com]
[Linked Image from inlinethumb46.webshots.com]
[Linked Image from inlinethumb11.webshots.com]
[Linked Image from inlinethumb35.webshots.com]
Mike Buller #205390 04/29/11 11:07 AM
Your belts look just like mine, even the same color.
Do have the anchor kits, so that should bee correct.
Tkhanks for your reply.
