#20497 12/04/03 04:51 PM
jle413 Offline OP
where can I find a list of pre 1936 engine casting numbers by year so that I can identify an engine.
#20498 12/04/03 05:38 PM
Hi,
Give this Block Numbers a try and see if it helps.
Agrin
#20499 12/05/03 01:57 AM
If you know the number post it here....we might be able to help! :) chevy
Mike Boteler
1935 Master Technical Advisor
#20500 12/05/03 10:02 AM
The casting number for a 1936 engine is 836010
#20501 12/05/03 11:12 AM
The following block casting numbers are from a list I have, but I don't recall where I got it. Maybe some others here can confirm them:
1929 - 835501 (all)
1930 - 836409 (all)
1931 - 836409 (all)
1932 - 836573 (all)
1933 - 837231 (CA Master)
1933 - 473180 (CC Std.)
1933 - 837231 (Truck)
1934 - 837231 (DA Master)
1934 - 473741 (DC Std.)
1934 - 837231 (Truck)
1935 - 836010 (all)
1936 - 836010 (all)
chevy -Bob
-BowTie Bob
#20502 12/05/03 11:22 AM
1930 is incorrect. Both 1929 and 1930 have the same block casting number of 835501. laugh laugh laugh laugh
#20503 12/05/03 05:04 PM
I believe that 1935 is 837597 and kwow 1936 is 836010.The 836010 1936 full length water jacket engine was used as a replacement for the original 1935 in the later years.
#20504 12/05/03 11:57 PM
The following is what I have in one file.
Year Model Block No.
1929 All 835501
1930 All 835501
1931 All 836409
1932 All 836573
1933 CA, O 837231
1933 CB 836915
1933 CC, 473180
1934 DA, 837231
1934 DB, P 837231
1934 DC 473741
1935 EA, ED 837591
1935 EB, EC, Q 837591
1936 All 836010
The engine cast number listed for the 1933 CB may also have been used in some Master passenger cars.
#20505 12/06/03 01:48 AM
Chip is correct, ALL 1935 blocks use casting number 837591.
However, the '35 engines did have two different Heads. The Early Head used 1934 style Valves with 45 degree seats and 15 long head bolts while the Late Head (serial number 4783317 and up, late March 1935) had 30 degree seats with "U" shaped valve keys and 7 short & 8 long head bolts. I believe the compression ratio also went from 5.45:1 to 5.6:1 (Early to Late).
chevy :)
Mike Boteler
#20506 12/06/03 02:50 PM
Thanks for the corrections, gentlemen. I'll update my records.
chevy -Bob
-BowTie Bob
