#204571 04/21/11 09:13 PM
stuscar Offline OP
On my '34 Master, should the inside surface of the hood and radiator shell be body color or black? It's been so long that I don't remember. Thanks, guys.
Stu Allen
stuscar #204608 04/22/11 09:36 AM
The under side of the hood was a medium dark gray color. The shell and the sheet metal behind the grille was black.
Chev Nut #204672 04/22/11 08:45 PM
stuscar Offline OP
Thanks, Gene. Would the Filling Station engine paint color be close enough?
Stu
stuscar #204679 04/22/11 10:19 PM
I would try to find some thing with less gloss as the paint was some type of a water proff primer. Actually the primer under the factory paint on top of the hood was the same. The body (Fisher Body) had red primer. The engine paint is a little too dark and would look like you used engine paint under the hood as a mistake besides being to glossy.
Chev Nut #204680 04/22/11 10:47 PM
stuscar Offline OP
Thanks, Gene. I'll look for something lighter with low gloss.
Stu
stuscar #204682 04/23/11 12:15 AM
Hi Gene,
So do you have any documentation on this being the case? And just as i asked this question I remember I had pictures of a 4000 mile 34 and your right.
So when your paint your hood, don't for get the over spray.
Bruce
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
