#204353 04/19/11 03:20 PM
Jay28 Offline OP
I picked up a set of Burd Graf-flex piston ring's for my 1928 4cyl and was woundering if anyone has used these ring's in there motor?
Are these good ring's to use or???
Where can one find info on these ring's?
Keeping vintage Chevy alive.
Jay28 #204393 04/19/11 09:34 PM
Do you have new pistons? Do you know the size of your rings? It is important to know what the entire setup is.
Agrin devil
Jay28 Offline OP
Hey AntiqueMachanic
The pistons are original and in great shape and clean.
The cyl wall's were cleaned up with a bottle hone, and new piston pins installed.
The piston ring's are Burd Graf-Flox 521 STD. @ 5/32.
Head has new valve's + spring's and all new gaskets top to bottom.
Hope this help's.
Jay28 #204488 04/20/11 09:59 PM
So you are reusing the same pistons and the new rings are standard. Have I got it correct?
Agrin devil
Jay28 #204502 04/21/11 12:54 AM
where did you find the piston pins?
thanks ron
Jay28 Offline OP
Hi AntiqueMechanic
I am reusing the original piston's and the new ring's are standard.
My motor has very low milage on it and is in great shape.
ron1967 #204569 04/21/11 09:05 PM
Jay28 Offline OP
Hi ron1967
I found a full set of new old stock piston pin's on Ebay.
They come up on Ebay once in awhile, they are hard to find, I don't know of any other source that sell's these old pin's.
If I come across another set for sale I will let you know, if you are looking for a set.
Jay28 #205026 04/26/11 02:09 AM
Pistons, rings and pins are readily available here in Oz, I have JP pistons in both my motors and have doen a lot of miles. Not sure on the current price but a full set with rings and pins was $500 a few years ago from them in Adelaide .RAY
RAYCYCLED #205028 04/26/11 02:13 AM
I have also been running JP pistons in my 28. Have had no problems in 35 years.
Cheers
Ray
