Posts: 549 |
so I finally got the exterior hold down ring for my 51 from the Impala bobs and I had gotten the key housing and key mech from NCA.
In case your wondering neither one sells the other part, very strange?
anyway
What are the key positions suppose to be. I put it in and I have a staight up and down and a left 1/4 turn or so at this point. The little "grove" cut in the dash allows the repop key housing to fit several ways.
thanks
"Frame Off" restoration, its a journey not a destination
If your car follows the normal pattern the vertical position will be the off position and where the key is removed.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Yes, Junkyard Dog is correct, vertical is on, not off.
Posts: 549 |
so I'm good to go? Oh I need a wiring harness, engine, tran, and a few other things first. thanks
You're ready for the highway ... good to go.
