Posts: 94 |
Can anyone tell me how tall the headlight post stanchion is on a 1931 Coach?
Posts: 94 |
Sorry, I meant to say 1930.
Posts: 360 |
karl
Posts: 94 |
I just ordered a set from I&I Reproductions and they are 9 3/4.
Posts: 360 |
I suspect my measurement may be slightly off, my measurement included the base. The posts I have also came from I&I. They matched the originals that were on the car exactly.
karl
Posts: 94 |
Thanks, do you know if there is any spacers between the frane and the fenders and splash apron that would make the stanchions sit higher? Right now thet don't reach the headlight bar.
Posts: 360 |
Also there is a rubber gasket that fits between the base of the stanchion and the apron. But that shouldn't be a factor in reaching the headlight bar. I suspect that you're missing the nut (with the shank) that fits under the headlight bar and holds the headlight in place once the headlights are properly aligned.
karl
Posts: 94 |
As always, thanks very much for the input.
Posts: 94 |
How long is the nut with the shank that fits under the bar?
Posts: 360 |
Not sure how long the shank is, but I would guess a half inch. They are available at the Filling Station (part number AF-154).If you call them I'm sure they can give you the specs. When you measured the posts, did you include the base (which is about a quarter of an inch).
karl
Posts: 94 |
I just remeasured and I get 9 7/8" top to bottom.
Still 1/8" short.....but it might work if you have the nuts with the shank and then maybe put a thin spacer under the stanchion base. I believe that Stanley's Parts in Fort Worth, Texas has the correct length stanchions.
