#203015 04/06/11 09:20 PM
Tyler Offline OP
Hey guys,
The time has come when I must sell my truck. I just wanted to let as many people know as possible becasue I want it to go to a good home. You can find the details here:
1928 Chevy Capital for sale
Hi,
Can you tell me about the breather tube coming off the oil filler and going into the carby??
Cheers
Ray
Tyler Offline OP
That is standard on 1928 only from what I have been told. It was originally a spiral wound metal tubing, but it had come apart and was not working anymore as a tube so I just replaced it with a piece of heater hose. It is just a pcv system without a pcv valve.
My two 1928 engines have a solid bent steel tube as the crankcase breather tube. They seem to be original.
Actually Tyler, that arrangement is NOT standard on any 1928 engine. The 28 engine is equipped with a PCV system consisting of the pipe that goes from the hole in the block near the water pump, to the connection provided for it on the input to the carburetor.
Another pipe goes from the input to the carburetor around behind the block and is connected to the heat stove on the header pipe.
Agrin devil
