I have a 1929 Imperial Sedan. I'm putting my car together after being apart for some time. I put the tie rod ends back together as directed in the 29-32 repair manual. There is no way the ball will go in, but it would if I put it together backwards. After looking at different pictures I see that the ball stud hole is closer to the tie rod than it is to the end plug end.Do I have the wrong tie rod ends? Would the ends I have work If put them together backwords? Thanks
Rob
