#202306 03/30/11 08:25 AM
I purchased a '57 station wagon. The speedometer cable is new but the speedometer needle bounces around and there is a loud growling comming from the spedo gauge. Does anyone know what the problem may be and how to repair it? I checked for kinks in the cable and all looks fine as there are no kinks or sharp bends. I disconnected the cable from the transmiission and I was able to twist it by hand and it moved freely as well without binding.
Any suggestions would be appreciated.
Wilwood Engineering1955-1957
Probably need to remove the speedometer and take apart. will mostlyu likely need to be cleaned and lubricated. did it to my 55 years ago. wasn't too bad--just time consuming. Have and aricle on procedure stashed away some where if needed.
Ken
The article would be appreciated.
Hey Ken, I have a '58 chevy bel air, would your info to take apart the speedometer for the '57 be the same for mine? It doesn't make the noise but I want to take it apart for cleaning and lub.
I would begin by removing the speed cable, lube the speedo cable, reinstall.
If you are sure that it is not the cable I would remove the speedometer and have it professionally cleaned, lubed and recalibrated.
Here is a link to an article similar to the one I have. Just be careful and take your time and you should be OK
http://www.classicchevy.com/techarticle/index/viewarticle/id/839
Ken
Having recently gone through this exercise on my '57, I would add a few things to that article.
First - speedometers should be lubricated with clock oil, not WD-40. I bought a spray can of clock cleaner and small bottle of clock oil off eBay for a very reasonable price.
Second - be very, very careful removing the needle. Carefully twist it counterclockwise. If it doesn't want to move, hold the speedometer face down, put a drop or two of WD-40, Liquid Wrench, or PB Blaster on the shaft, and let it soak into the shaft/needle joint. Wait a few minutes, then try again. It'll come if you're patient.
As you take things apart, keep a sharp eye so you don't lose the tiny jewels on the shaft. It's best to disassemble things with the speedometer face up.
Soak the daylights out of the thing with the cleaning solvent. Let it dry, and carefully oil all moving parts. If it's still sticky, you may need to disassemble the magnet/wheel assembly. It's incredibly easy to break things doing this, so do it only as a last resort.
The magnet/wheel need to be carefully aligned so they don't drag when the cable connector is spun. Start by getting the shaft approximately in the middle of the outer wheel, and tweak as needed. Hold the speedometer facing you. When you spin the cable connector (clockwise) quickly and let go, the wheel should return and bounce a couple of times as it hits its stop. There should be no noise while doing this.
Hope this helps.
