#202276 03/29/11 10:32 PM
Hi,
Can someone tell me if there should be some type of webbing that goes between that cowl, running board aprons and the frame on a 32 1/2 ton?
Should there be welt at the fenders?
Thank you
Ed
32 1/2 ton panel delivery
55 Cameo
And a Plymouth
fdwrench #202281 03/29/11 11:27 PM
There was no webbing on the top of the frame rails or between the body and frame. There were fabric pads between frame mounts and body at each bolt.
A bead type fender welting was used between splash aprons, front fender, running board. Never found the beaded welting on rear fenders but did find a fabric between the fenders and metal spacer and spacer to pickup box.
Chipper #202393 03/31/11 08:48 AM
Thank you
Ed
55 Cameo
And a Plymouth
Chipper #202969 04/06/11 03:50 PM
Would this apply to a 29 also?
Erik Langhofer
Phoenix, Az.
