#201935 03/25/11 02:32 PM
brownie Offline OP
I have a Chevrolet 327 engine that I have had for a little more than 20 years. There are two steel stampings on the ID section. One in small steel stamps 18S193737 and one in a bit larger steel stamps of V0224HF. What can you tell me about this engine....
Brownie Petersen
TA#69 1949-52 Steel Station Wagons
Chat Group Member
Wilwood Engineering1955-1957
My info. shows the HF as a 1966-1967 275 HP 327 engine. This was the most common optional 327 engine for passenger cars. Should have a 4 bbarrel carburetor. They came with either a Rochester Quadrajet, Carter or Holley.
brownie Offline OP
It was in a 1966 Corvette that I purchased that was T-boned and stored from the late 60's until I purchased. It came with an Edelbrock 3 X 2's manifold and carb setup with progressive linkage. The carbs are Rochesters. I was going to put it in the El Camino but I do not have the heart to change out an engine that is in an all original car. Do they have any value?
Brownie Petersen
Chat Group Member
The V0224HF Breaks down as:
V = Flint Engine or Flint V8
02 = February Build month
24 = 24th day of the month
HF = Gene gave the answer
18S193737 identifies the vehicle it was installed in (VIN)
1 = Chevrolet Division identifier
8 = model year 1968
193737 = vehicle build sequence number
Interestingly, the last Chevrolet Passenger car assembled at the Stain Louis Plant in February of 1968 carried sequence number 194331. Your engine was installed in a vehicle 594 units before the last February build unit. That's pretty quick turn around when you think about the engine being built in Flint on 2-24-68 and installed in a vehicle at Saint Louis before the end of the month. Was 1968 a leap year? Even so, four or five days is quick.
The stamped engine number 18S193737 does not work for a 1968 Corvette. The 1968 Corvette numbers ranged from 8S400001 through 8S428566. Now if the serial number you listed is actally 6S, and not 8S, what I wrote earlier is meaningless.
brownie Offline OP
No, I trust your data. I would expect that the 66 Corvette that I purchased was the recipient of an engine exchange. It is not a large leap to expect that somewhere along the way the engine was changed out.
Brownie Petersen
Chat Group Member
The 275 HP engine was not available in a Corvette. The 300 HP was the
base"
The 275 came in the Full size car, Chevelle, ChevyII, and Camaro.
