Hi, I did a frame off restoration on my 1948 Chevy convertible and need to install a set of NOS Fog lamps. This may sound funny but even with the directions I am not clear on how the wiring connect on the switch end. Keep in mind this is a correct NOS unit! The switch has 3 terminals.
1. The directions indicate to splice the two fog light wires together approximately where the junction block is on the driver’s side wheel well, understood.
2. Then wire the ignition to battery terminal on switch together, understood.
3. Next is what is confusing and I wrote it as it is on the directions “connect wire from tail terminal on switch to tail lamp terminal on lighting switch”
4. Also no mention to connect wire coming from fogs.
The diagram picture shows a wire from the fogs to the switch, a wire from switch to a dot with a leader to (2) above and then a wire from switch to a dot with leader to (3) above.
Now I can go ahead and make the connections per (2) and (4), but that only uses two of the three terminals on the switch.
Is there anyone who can help me with this? Is there a third connection to the light switch? If so, to what terminal of the light switch. I built this car as correct as possible and this is one of the last accessories to install but I want a correct installation.
Johnny
www.1948chevy.com
