Posts: 229 |
Does anyone know where I can find the oil pump/distriburtor thrust washers. 1" O.D. by 1/2" I.D. by 0.075 in thick. All I can find are sintered bronze at 1/16" (0.062) and 1/8" (0.125) thick. The 1/16 is too thin and the 1/8" is too thick. McMaster Carr did not have what I needed. In order to remove the play I have to be able to use a variety of thicknesses. I have 3 different distributors and neither of them have the same amount of end play.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
The Fillingstation www.fillingstation.com sells the thrust washers . part number FS-435
JACK
Posts: 191 |
While we're onto oil pumps, I've just installed a new gear pump on my '32. Is priming needed and if so, what's the best way to do it?
Before you start the engine , remove the spark plugs or disconnect the ignition , and crank the engine over until the oil pressure comes up on the gauge. Reinstall the plugs and ignition , and you can then start the engine as normal.
JACK
Posts: 980 |
You could remove the oil distributor and prime the pump through the bottom hole in the block using a squirt oil can.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Posts: 229 |
I would prime if I were you. Take a steel rod about 18" long the same dia as the end of the dist shaft and cut a slot in the end like the end ofthe dist shaft. Use an electric drill to turn the new shaft after you slide it into position on the new oil pump. It is quick and easy and will also prime the oil throughout the engine before you replace the distribotor.
