#200749 03/14/11 11:08 AM
Oreo Offline OP
I will be using new pine boards in the bed of my 52 pick-up restoration. They obviously were black originally, and I want to keep the original look. Any recommendations on the paint to use, and is it a gloss wood paint, or semi-gloss? Assume the steel bed strips are standard gloss black.
This may have been covered before, but I couldn't find any postings.
Thanks.
There are many choices on the paint and how you paint the wood. No matter what you choose to use I would try to do three things to assure a long lasting finish that will hold up for years, especially in the sun. I would try to use a marine grade of paint and if I couldn't, I would use a marine Spar-Varnish as a final coat to keep the sun ultra-violet rays out and whatever water got on the finish from runing it. Even more important, I would paint ALL sides of the lumber, the top, the bottom, the side edges and the end edges. In other words, seal the wood from all possible mositure. It works and you will enjoy the look of the finish for a long time if you follow these ideas. Most likely, because of the number of coats of material you will have to apply to the lumber to achieve the goals I have listed, the finish may come up on the glossy side, but I would not let that stop me.
See Facebook Page for Joe Fuchs to see more pictures of my 1937 Chevrolet 1/2 Ton Pickup
Oreo Offline OP
Thanks for the advice-time to start investigating products. At least the color choice is not an issue.
