#200796 03/14/11 07:37 PM
I appear to be leaking antifreeze between the engine and trans of my 1948 fleetmaster with the original 216ci and 3 speed trans. any tips or tricks for pull the trans? Would it be better to pull the motor? Any insight? Is there even a freeze plug on the back!?
There is a freeze plug on the back of the engine block and as far as I know you will have to pull the engine to get at it.
ken48
VCCA 42589
ken48 #200814 03/14/11 10:10 PM
BEAUTIFUL CAR!
Thanks for the info, is it possible or any easier to pull the trans out? or would pulling the motor the the best bet?
If you pull the transmission the flywheel housing and fly wheel will also need to be pulled.
