Posts: 26 |
I have been having problems with my 1931 five window coupe. I kept the battery charged throughout the winter, however when I tested the battery, I decided to replace it. I installed the new battery and the next day discovered that the battery was dead. I disconnected the battery and charged it again. Then I started the car and drove for about thirty minutes. I then put the charger back on the battery and it was almost out of juice. The gauge shows that the battery is charging and never goes into the negative when I am driving. I am wondering if somehow a short has developed. I wonder if anyone would have some advice for me as to where to look first?
Thank you,
Posts: 980 |
An easy first check is to see if the contacts in the generator cut-out are stuck. With everything turned off, a 6 volt test light in series with the battery terminal and the wire terminal will tell you if there is a short circuit.
If you have old Chevrolets, other old Chevrolets will find out where you live.
Posts: 26 |
Thank you for your comments. I intend to try to trouble shoot it this weekend.
Posts: 980 |
If you had a real short circuit it would blow the fuse or burn some wiring. What you may have is a partial electrical load, something is on that shouldn't be. The test light tell you. If there's no indication of a short circuit or partial load and you are sure the battery is fully charged, I would suspect a starter problem.
Posts: 680 |
Quick Test. Pull the Neg. cable. Looking real carefully just Tap the Neg.post with the cable. Look for a slight arcing. If it arcs you trouble shoot the system,if it doesn't, go ahead and charge the Battery. At full charge using a Digital Volt Meter check the level of Voltage over a few days. If it continues to drop, replace the Battery. Al W.
It's Wise to choose a six!
