I needed a new oil pan drain plug because the hex on mine was all rounded and useless. I found that NAPA has the plugs for $2.00 including the gasket. The plug size is 1/2-20 (1/2 inch diameter and 20 threads per inch). This same plug will probably fit other years beyond 1951. Don Hampton.
Don H
The drain plug is one of a few Chevrolet parts that span 50+ years of Chevys. 7/16"-20 lug nuts are another. At one time I was going to put together a list of the parts used for the most years but ran out of time.
A 1931 Clutch Plate will fit a VEGA also.
Joined VCCA June 1, 1961
Will the Vega clutch plate fit the 31?
Mr. Mack. I don't know. I was changing the clutch for our daughter-in-law. She had purchased a new coutch. When I got it apart it looked like a 31 clutch. I had about a dozen used 31 clutch plates. I used one of the old ones and asked her to take the new one back for a refund. I have never tried to go the other way.
One time on a Glidden tour a friend lost his clutch on a 29 Packard. He got a new clutch plate at a tow-motor repair facility and was on the road the next day.
That's some good information to know...especially if you own a Vega. bigl
.....or live near someone who does.
"It's wise to choose a SIX"
I thought they all rusted out on the show room floor.
karl
I went to NAPA and got one ($1.83 to be exact) and the part number is 704-1020 Drain Plug.
My Chevy is over 70 years old and still running great. I hope I keep running cuz I just turned 81 !!
I made several by cutting the threads off a 1/2-20 bolt and scew a jam nut on and weld the end. Grind weld flush and bingo.
