Posts: 65 Likes: 1
Posts: 65 Likes: 1 |
My '54 has an aftermarket cooler for the ATF. I found a nice original cooler that I'm going to install. Is there a bracket that it attaches to? Engine is out of my car and at rebuilder, so I don't have a reference at the moment. Thanks so much!
Dane '54 210
I f you send me your email address I will send you a picture of the cooler installed on an engine.
Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
The cooler on my 54 has a bracket welded to the cooler and it is attached to the timing gear cover by two long screws that hold the timing gear cover on. It mounts on the back of the timing gear cover. It is painted the same blue as the engine. Is that coreect Gene? It was on the car when I purchased it.
Joined VCCA June 1, 1961
