#197077 02/03/11 11:55 PM
1922c Offline OP
I found and bought a 1929 sedan..
Job#8850 Body #0 4952 vin# 473051 can it be identified? Engine frozen two cylinders appear to been full of water. The rest of the car looks good.
1922c #197078 02/04/11 12:05 AM
8850: 1929 Standard Sedan
O: "O" represents the Oakland, California factory.
4952: 4,952nd Standard Sedan made in the Oakland factory in 1929.
473051: That appears to be the engine serial number and not the Car Serial Number (VIN). By the way, the early Chevrolets did not have a "VIN" number. The number was actually called a "Car Serial Number" and it was stamped on a small plate that was attached to the passenger side wood main sill, under the floor mat, facing the passenger door.
1922c #197293 02/05/11 10:47 PM
1922c Offline OP
Thanks.I found numbers on the engine 835501 0-23-9 2
1922c #197298 02/06/11 12:22 AM
The block casting number 835501 is a '29 or '30 block. I suspect that the date code is D 23 9 or April 23 1929. O was not used as it would have been the 15th month in the year.
