Posts: 437 Likes: 1
Posts: 437 Likes: 1 |
I have a 1953 chev with a 54 block and 56 head according to serial numbers. I currently have solid lifters and contemplating changing them to hydraulic lifters. Is it just a matter of taking out the SL and replacing it with the HL and then adjusting? Or am I oversimplifying the process and other parts must also be changed?
Paul If it isn't broken, fiddle with it anyway so you have something to repair. 1931 Deluxe Sport Roadster 1953 BelAir 4 dr. Sedan 1965 Chevy II Nova SS
Posts: 1,178 |
You will have to change cams, the cam ramps are different.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
With the hydraulics, I believe there needs to be an oil passage, going in a horizontal direction, through the lifter bores, only found on hydraulic lifter engines.
Posts: 11,162 |
Unless the 54 engine block is a truck engine block it should have hydraulic lifters from the factory. Well let me take that back, if it is a US engine.
Posts: 437 |
I think the '54 and '55 stick shift engines have solid lifters. My '55 235 has solid lifters. And when we put a power glide '54 engine in a '50 hardtop we had a lot of trouble with the replacement lifters. Those replacement lifters were part of the cost of in a great engine shop in our area....My advice - stick with solid lifters.
The pre 1958 blocks are not drilled for oil that fills the lifters. The 1958-1962 blocks have a different oiling system and they can interchange lifters. Agree, the modern replacement lifters leave much to be desired.(solid or hydraulic)....and that goes for the camshafts also.
