#196533 01/28/11 07:03 PM
jgeorge Offline OP
http://i1105.photobucket.com/albums/h355/joe15747/fuel-line.jpg
is this normal or is the fuel line cracked?
this is my first attempt at posting a picture.
jgeorge #196539 01/28/11 07:55 PM
Yes the fuel line is made with a seam. If it is not leaking then its not cracked.
jgeorge #196540 01/28/11 07:58 PM
Hello jgeorge,
The picture of the fuel line appears to be stained along the seam. You might clean and dry the fuel line and reconnect it to the fitting. Try pressurizing the line and check for leaks. Use facial tissue to verify presence of fuel moisture. If required, make necessary repairs.
